Re: Yamaha F150 Twins have different rpms at WOT
I think the HP tolerance is plus or minus 15% for an industry stndard. if you dyno the engines or run them on a test wheel and they fall into spec its no worries and is quite normal. however if both can pull the same on the test wheel or dyno you my have a mounting or hull issue, if its mounting or hull its not a yamaha issue. you may also ask to test another prop or style of props. I would like to see the speeds that YAMAHA published for a parker. most likly its published by parker. so far yamaha does not make outboard boats in the states but they do supply some hull manufactures with a product just like the manufacturer of your VHF and bilge pumps. parker installed them but did not mke them. its crazy sometimes but its not like buying an automobile. you would not belive the amount of gearcases and control boxes I see fail cause the rigging was done with the elcheapo super failure prone teleflex cables. then try to find out who is responsible for the warrenty. is it a yam issue, a rigging issue or a teleflex issue? in the end its the consumer that gets stuck about half the time. a lot of hull riggers tend to use the elcheapo stuff, especialy on smaller packages where the profit mrgine is low to start with, key switches are a good one and I have experience with that issue. we had a 7 month old hull come in with a 90 yamaha with a total meltdown of the engine harness due to a defective marineworks keyswitch. yamaha said it was not a yamaha failure, marine works said they only warrenteed the switch for 90 days, the hull manufactuere said their 10 year warrenty only coverd the hull and the only warrenty on rigging items was from the rigging component manufacturer. cost the poor customer close to 800 dollars but in the end yamaha did sell him a key switch assy at cost. marine works keyswitch 22 dollars the yamaha one is about 140.<br /> what my point is is that you have to first identify if there is an actual problem then identify where the problem,if any,lies and who is responsible for it.<br /> also recheck the commnd link setup to insure the trim gauges where set correctly. then verify the tachs with n inductive pickup shop tachometer.<br /> luckily my experience with Parker is mostly positive and they usually use quality rigging and materiels, if it was rigged by prker and not at someplace else.<br /> its the same with cars, if you bought two of the ame model from chevy and tested them at WOT and idle would they be identical or could mnufcturing tolerance allow ome differences. IROC cars are expensive because they have been blueprinted, they are stock but now identical.
