the sand flea
- Nov 2, 2015
- 3
I've been fighting ethanol issues for some time now. I've replaced the electric pump, filters, fuel lines under the cover, the vst pressure regulator and now I'm perplexed! The engine idles great in the driveway but after a short run it will run rough, dump fuel overboard and eventually flood itself at idle.
I test the PSI from the mechanical pump and get up to 12 PSI. How can this happen and what is the remedy? I prefer not to just change out the pumps at over $200.00 each and really fix the issue.
