Re: Yamaha F115 power loss
Mazanek,<br />When we initially had problems Yamaha NZ said the injectors carn't be cleaned and they only had 2 in the country. No offer to import more. We needed 8 injectors so we made some equipment to back flush them, test shut off and spray patterns. The equipment worked realy well for removing the crap out of the injectors that the standard F115 filters let through. The second time we paid professional injector cleaners as we wanted an independant report incase we took the matter further. They removed the inlet baskets, ultrasonic cleaned them as well as measuring the continuous and pulse flow rates. The cost was 1/10th of the cost of new injectors. Yamaha NZ now say the injector manufacture does not recommend cleaning the injectors. The injectors are made by Denso under licence to Bosch. Denso won't tell flow specification, impedance, resistance, recommended filtration levels or any other good to know stuff as they bound by a OEM confidenciality agreement. Yamaha won't tell because they want to sell you new injectors. I would get the professionals to clean mine again if it was me. Bosch recommend and say it is common practice to cleaning EFI injectors. (not mechanical injectors tho). If it is contaminated injectors make sure your motor tech makes a really, really, really, really good job of cleaning the fuel system especially the pressure regulator. Or even better, fit a pressure filter before the injector rail.
http://www.cantonracingproducts.com/pr_25907.htm looks like a particularly good one. I have trouble smelling petrol in the oil at lower levels but a good trick is to spread a few drops from the dip stick onto some coffee filter paper - makes a big difference. Remember the first instruction in the Yamaha maintenance manual when changing the engine oil is "CHECK FOR GAS IN THE OIL"
