Hello fellow boaters. I am having some issues with my 2004 Yamaha F115TR (4-stroke) and could use some good advice. The motor came on a 2004 Sea-Pro 180cc that I bought last year. The only thing that was not stock on the motor was the prop (13 x 19 instead of the lower pitched 13 x 17).
She ran at about 5800RPM WOT and had a top speed of about 40mph. My only issue was that it took about 10 seconds to get up on a plane, but I figured that was probably caused by the prop pitch combined with the 4 stroke's weight in the back.
Last week I was headed off-shore with some buddies to slay some Amberjacks when the boat suddenly started to lose it's plane. The engine sounded like it was bogging a bit, the rpms dropped and the boat slowed to about 15 mph at full throttle. We turned around and started to idle back. Once in the harbor I wanted to see if the problem had gone away and to my suprise it had.... for a minute. Then it happened again.
Technically this is not the first time that this has happened. Once before the same thing occurred and the dealer claimed it was dirty fuel injectors. He blamed it on Sea-Pro not installing fuel-water separators on their boats. So, one fuel-water separator and $400 dollars later I had my boat up and running again.
So this will be the second time this has happened in a 6 month time-frame, however the tests that diagnosed the problem last time are now showing up negative. Last time the technician removed one injector connector at a time while idling which revealed a dead cylinder, and this time when I did the same all appear to be running fine. I have a clean fuel filter, a brand new fuel-water separator, the primer bulb is always full of pressure and my plugs are in great shape.
Oh, one last detail. When the problem occurs on the water, giving the engine full throttle pushes it up to about 3000 rpm and that's all it has. However if you pump the throttle once or twice it will gradually increase until it gets up on a plane. The funny thing is that you have to keep pumping otherwise it will eventually die back down. What the heck is going on?
Could this be anything but clogged fuel injectors? Why would this happen again? What is the best way to diagnose and fix this problem without spending a fortune and how can it be prevented from happening in the future?
Any help is greatly appreciated.
