JoeKubinec
- Jul 7, 2003
- 1
Engine revs in neutral properly to max (5500) RPM, but will not rev beyond 2300 RPM and vibrates badly when in gear.The engine has a RPM restrictor if cooling and/or oil pressure do not meet spec, but there is no alarm to indicate that either is a problem. Oil level correct and proper cooling flow discharge. Prop looks good. No visible external problem. Engine harder to start than usual (had to use starting fluid). Where do I start to look for a problem?
