I am doing a water pump change on a 1992 CV40 and unsure of the rubber grommet location where the housing fits on the water tube. Most of my experience is with OMC motors and I know them. When I removed a the water pump housing the grommet was on the inside of the housing in the water tube slot. Most others I have dealt with were on the outside pushed in from the top. I assembled it as it was and there is a lot of water coming out between the lower unit and the mid-section. Water is flowing well from the telltale and motor is running cool. Any info is helpful. Thanks in advance.
