Yamaha carburetor issue
Danfromvan
hi
I have a 1993 Yamaha T9.9 ELHR 4 stroke
this motor will will start on half a crank
idles like a kitten purring
runs WOT BEUTIFULLY
ISSUE :
shen accelerating it coughs ,sputters ,backfires though the carb
i don’t think it can get sny cleaner
replaced a wack of parts
been trying to order a new carb and all I can find is a 2 stroke model
tearing my hair out over this
I’m a carpenter not a mechanic but I can usually figure these things out
any suggestions ??
thznk you
KLFrank
Look into the fuel filter. It will idle smooth with little gas. It will run WOT with little gas. The fuel is starving and running lean, restricted by the fuel filter. On acceleration is when the demand for fuel is needed. Just a thought. Hope it helps
99yam40
4 stroke motor backfiring thru carb means it is firing a cylinder with an intake valve open
