Yamaha carb drain broke
jc turtle
I have a 1989 Yamaha 115 hp carb 115etlf that the bowl drain broke coming out. Should I try to get out the broken half in the carb, or epoxy up the hole? Drilling it out would be difficult but not impossible.
thank you,
John
Chris1956
Honorary Supreme Mariner
A picture would help. Do you ever drain the carb bowls? If so, why?
Could you drive a SS self tapping screw into the remains of the drain to seal it?
jc turtle
Good idea. It is a very small hole, perhaps 1/16”. I will check it out. Thank you. John
Chris1956
"Permatex Gasket Dressing and Sealant" is immune to fuel. You could put it on the threads or use a rubber washer on the screw, or both.
