Hello,<br /><br />I did do a key word search on this board and I did not find my answer so I will ask it in hope of an answer from anyone that had the same problem.<br /><br />I have a 90 yamaha 250. has a trim switch on the control and on the outboard. The switch on the outboards works fine up and down. <br /><br />The problem is the down on the control switch. I know for a fact it is not the switch. I tested it. While I had undid the plug I jumped it and the thing actually went down for a second. Then I knew that it was not a wire connection. I did not try to jump the wires on the outboard cause I did not have a manual. I know though that it is light green and light blue for the up/down.<br /><br />I was reading some posting about the relay going out. But I was thinking to myself, how can it be the relay if I still can tilt it down from the outboard motor switch ? Are there 2 separate relays for the control switch and the outboard switch?<br /><br />Any help will be appreciated.
