msmith1356
- Sep 12, 2010
- 3
So the other day, in a hurry, i hooked up the battery backwards. Bonehead move! Anyways, tracked down the 20A inline fuse, replaced it and everything 'seems' to work. It'll crank and the tilt works.
I have been reading that crossing the polarity on the battery will fry the rectifier in a heart beat. So my question is, how do i test if it works? I have read on a number of posts to check resistance between the different leads, then swap them...showing that current can only move one way. But when i do this, i seem to be getting different readings than anything i'm seeing online.
The unit has 4 wires coming from it, Red, Black, and 2 Green's. When i test between the Red and Greens or the Black and Greens, this works correct...current only travels in one direction. But when i test Red to Black, it works in both directions.
Does this mean it's fried?
