This motor has 3 carbs and you mix the oil with the fuel. Before the season I changed all the jets, the float needles and seats and the idler needles as well as the fuel pump and the fuel filter and the spark plugs. I had water in my gas so it wouldn't start until I changed my gas. Then I had steering problems so I couldn't take it out until I fixed it. Now after pulling about 200 lbs on the tube for about 20 minutes my motor revs down to about 30% full throttle. If I put it in neutral, it will die, but if I let it sit for about a minute it will start right up and run correctly for about a minute of two. The pee hole is circulating water fine. There is no overheating alarm, though I've never heard one on this motor, so I don't know if it works. Any guesses?
