Jschultz
- Jul 12, 2020
- 5
Hello everyone! I’m new to the forum but as you can guess I’m having engine troubles. I have a Yamaha C115 TLRX outboard that has started overheating over 2000 rpms. I’ve replaced the thermostats, water pump impeller and housing, poppit valve and spring and it continues to overheat. I’ve recently pulled the heads to inspect water passages and found very little corrosion/debris around the water jackets. Am I overlooking something? I can’t think of anything else that would cause the alarm and rev limiter to go off. The engine is getting around 170 degrees when it overheats...
