yamaha air cooled 5hp. 5bs 661 non starter - crank seals?
dieseldod
hi lads, above motor has GOOD spark /compression /timing/fuel delivery. i,m near sure its the crank seals. even putting petrol into bore it wont fire. where would i get new seals ? any chance of a manual for this old critter?
Well it should fire with fuel in the bore.----Crank seals are not involved in 2 stroke compression.----I say you have weak spark.----Does spark jump a gap of 1/4" ( 6 mm ) or more ?
dieseldod
thanks for reply ,yes thats the bit thats got me, i checked the woodruff key yesterday , good fat spark far superior to modern efforts at spark
dieseldod
ive tried different points gap settings between 12-20 thou still the same wonder what the right gap is meant to be?
