yamaha9990
- Jun 13, 2010
- 7
I may be making some progress, but could still use some objective advice.
Bought it used, no problems reported. Died on first trip out. Maybe out of gas.
Thereafter, stalls in neutral and when pushed into forward. When can get revs to 12000 ok. Ruins great at speed. Have changed fuel/water sep, fuel filter and plugs. Had the carb pilot jets sprayed with carb cleaner.
Local shop says carb rebuild necc but only 50/50 chance of improvement. Also said that carbs no longer made by Yamaha and unavailable.
Have shocked with Ring Free and some other additive. Perhaps slight improvement. Seems to run better when red choke under cover is employed.
Should I try to continue with additives and hope it will clear? Anyone with experience with this.? Trying not to waste money on a lost cause. Thanks!
