Hello
I just picked up a 90tlrp. Price was right. Some issues though. It did not have a lower unit. The controls were cut 12 inches from the 703 controls. I was told it had low compression on one cylinder. Motor besides that looks new under cowling. Was properly stored and looks used very little.
So my question is where to start?? I can't do a proper compression test. Figure I need to replace the wire harness from control to motor. Put some power to it so I can turn it over?
I have a couple manuals on order. I am going to set it up for a jet so I'mlooking around for a lower.
So my initial question is if I put power to it is it okay to turn it over without a lower?? Are there any other things I can inspect to see if I have a viable motor?
What I'm trying to avoid is putting a ton of money into it without an idea of what I have
Any help would be appreciated
1991 90tlrp. 2 stoke oil injected
