i purchased a used 1997 yamaha 90 and installed it on my 19 foot carolina skiff,i had no prop so i tried a 13x19 max rpm's were 2400 i then looked at website for yamaha and they recomend a 13 1/4x17 so that is what i purchased and put that prop on my max rpm now is 2900 and if i force it or try to go faster it overheats?(in other words i can only put the throttle to 3/4 of the way after that i press and no response at all from engine) the buzzer goes off and it drops to 2000 rpm's and i check the weep hole and it is not hot but i let it cool down and within a few minutes it is fine and i drive off, i have been using this boat like this for the last 3 months just not going over 2900 rpm and have had no trouble<br />i have rebuilt the carbs,replaced the fuel pump,water pump,spark plugs and i checked the electronics and the stater was reading incorrectly so i replaced it and that was not it<br />i dont want to waste any more money but i cannot afford to send to the dealer, any ideas would help<br />also compression was 115,115,120 and while running we try the primer bulb and it is hard but i replaced it also just in case and still no full rpm's thanks tojorge@yahoo.com
