Hi all, I've just got back into boating after 20 years away from it. The boat I have now has a 1992 Yamaha 90 on it. I took it out and found it would only pull 4600rpm. It was just installed on the boat to replace the older motor that had been on it. Has the correct new 703 control box. <br /><br />What I am wondering is is it possible that I am not achieving full throttle? Can the cable be adjusted? It is possible that the marine shop that installed this engine for me did not check throttle throw as it was not tested on the water and in conjunction with other things I have found since,I'm not 100% sure of their work.<br /><br />I don't think it is the prop as the boat is about 2000lbs loaded and the prop is only a 17 pitch.<br /><br />Any help or suggestions would be appreciated.
