I’ve read a lot of great things on these forums after finding this site recently, but still can’t seem to nail down my problem. Motor starts easy on first pull, but runs rough with misfires at higher rpm, and timing light shows no spark with the miss-fires. I’ve checked resistance and peak voltages (with DVA adapter) of every electrical component (there aren’t that many on these simple little motors) and its all in spec per service manual. Compression is about 98PSI on each cylinder. I’ve run with kill switch and oil pressure sensor disconnected to rule out any wiring issue there. Timing does advance properly to 30 BTDC, so CDI box is doing its job. I resorted to just buying a new ignition coil to try and fix the issue, but no luck with that. Even temporarily borrowed a known-good CDI. I assumed it had to be electrical since the timing light shows the symptom, but can a fuel issue indirectly cause an electrical misfire just by throwing timing off? This short YouTube video shows the problem with more details in the description of testing I’ve already done.
https://m.youtube.com/watch?v=IXGMdeszy40
If anyone can help me from going insane with this motor I’d greatly appreciate it!
