Yamaha 9.9 Engine Rattled then stopped altogeher, gear lever no longer engages and totally lose
Balina22
Hey all, looking for some starting suggestions on what may be the issue. Very inopportune time as I was about to take a potential new co-owner on a test drive the following day.
Engine:
How it happened: Was running the motor fine for about 2 hours then stopped for some lunch. Once restarted a rattling noise begin and the engine would die shortly thereafter. Tried to start it with limited success (would start and rattle) then die within 10-15 seconds. I then noticed I had attached the gas hose backwards (great move....) so the engine stopping was likely due to lack of gas, but the rattling? Flipped the hose, gave her a pump, started, rattled, stopped. Then noticed that the gear shifter itself had gone all slack without any resistance in either direction.
Any sugessions as to where I might begin my investigation?
Thanks very much in advance!
Edit: I should mention as I continue reading about the issue, the rattle I describe was very loud and it didn't sound like it was coming from the lower unit. I could be wrong but it sounded like it was happening in the powerhead itself.
