Yamaha '86 200hp motor not firing
tunacatch
Yamaha 1986 200hp motor model #200ETXK...motor will turn over, but have no fire to spark plugs. I have replaced the CDI unit, checked the kill switch, battery coil, iginition coil, trigger coils, and rectifier/regulator. Since the boat has twins, I've switched and checked the key switch leads, iginition control unit, and starter.<br />Have excessively high amperage draw when starter is engaged (+400a). Suggestions? Thanks!
