I have a 1984 Yamaha Oil Injection .<br />Here we go if disconnect the gas and let stand and do not use the engine for a couple of weeks, the lower cyclinder fills up with oil. I don't know if this is created from the heat from the sun or what. I brought this engine in and had them look at it and they said that the Oil Injection was working fine, but they did mention that if I did leave the gas hooked up to the engine this could be the results..The engine runs fine after I clean the cyclinder...I did not run engine out of gas...any help would be appreciated<br />thanks
