Re: yamaha 70 hp 2 stroke my 2010 buying advice
These (70 &90) IMO are some of Yamahas best motors. The reliability of these 3 cyl motors I feel gave Yamaha credibility and presence in the outboard market back in the early 80's.
The 90 that I owned was used long and hard for almost ten years. The selling dealer gave me two good bits of advice. A mechanic later gave me another.
I was told to always flush the motor, tilt it slightly and remove the fuel hose and always let the carbs run dry. I did. Also he said to mist a light coat of wd 40 over the inside and outside of the motor. I did. He mentioned using Yamaha marine grease and using my finger, put a light coat on the tilt/trim rams, motor, tilt tube and to ALWAYS clean and grease the steering shaft.
So, ten years and about 1500 hrs later I had yet to have a problem of any sort. It got impellers and plugs and lower unit oil every other year. It also was run on synthetic oil, in the gearcase and with the gas. Nothing on that motor ever failed in that time. Towards the end before I sold it, it began to run a litlle hot. The new owner had the cylinder head removed and corrosion in the passages releived. Nowadays I use SaltAway when I flush and help to prevent that.
Good luck, you're about to buy a great motor.
