I got the guage to work, it was plugged into the right socket, I just didn't have the rest of the wires beside the plug hooked to the guage. It wasn't getting any power! Thanks for your help. Now I have another electrical question. The wiring harness to the guage has extra places where you can wire up accesories. The yellow keyed power wire has an inline 10 amp fuse. I ran power to a fuel guage and a volt guage and the front green/red running light. All worked fine. Then when I tried to power the lights inside the two guages i had set up, the 10 amp fuse blew, I put in anpther one and it also blew. Should those couple of guages and lights blow 1- amp fuses? Would it be a bad idea to put a bigger fuse in? Also there is a blue wire hanging from the harness with a male plug on it and I don't know what it is for. Any ideas?
