Yamaha 60 Shift Problem
Paul_Dublin
Yamaha 60 (1995 3-cyl) won't go into gear.<br />It was a big stiff getting in and out over the last few times and not wont go into forward or reverse.<br />Cable is OK and I disconnected it and tried to manually move it. It won't click into gear and feels "springy" as if it's not moving at the other end and the rod is flexing.<br />If it likely that the cam has siezed on the lower unit shifter?<br /><br />I also noticed water in the oil when I drained it yesterday so I hope it's not terminal??
