Paul_Dublin
- May 30, 2004
- 32
Have a pair of 1996 Yam 60s with strange problem on one.<br />Ran for about 2 hours perfect, and kept revs to no more than 5500-5600. Stopped fine and ran fine on all revs. Came back in to harbour and backed off throttle to idle for a few mins and then moved off again. Power seemed to be right down as if it was not sparking on all cylinders. It seemed to get bogged down and then it would pick up after about 3000rpm.<br />Did this for the next few minutes where it would idle OK, bog down at low revs and then surge forward.<br /><br />Next day, ran perfectly all day again, but just as we were heading back the same motor seemed to be down a bit on power. Would only get about 5200revs where I had to back off before to stop it getting more than 5500 (It reached 5800 for a few seconds once).<br /><br />Carbs were recently cleaned and cooling seems to be fine on the motor (telltale is good and water coming out all the right places).<br />I would assume the fuel pump either works or not, so wouldnt just cure itself after a nights sleep.<br /><br />Is there anything that would cause this loss of power at low revs and then surging?<br /><br />Is it possible the motor thinks its overheating?<br /><br />What should I look out for?
