Paul_Dublin
- May 30, 2004
- 32
Have a pair pr Yam 60's (1996).<br />Both run and start well. Both identical props.<br />Left motor down on power, so did rebuild with OS pistons. Got compression up to 125/125/110 but it's still not getting as much power as the other motor.<br />"Good" motor will get over 5700RPM (will always back off to 5500)<br />The weak motor will struggle to get more than 5200.<br />I've tried swopping the complete carbs but this makes no difference.<br />The fuel pump seems to be pumping well when tested and no visable restrictions on the fuel lines.<br /><br />Is it possibly the timing?<br />As the other motor is identical, is there anything I should swop as a test?<br /><br />Any other suggestions?
