Julian Smart
- Dec 13, 2006
- 10
Hi
I have a 1997 50 hp yamaha will run great for about 10 minutes then will loose power stale and not really start again if it does as soon as you put in gear it stops and sounds rough when in neutral. If you remove cover and leave for about 10 minutes it will start, but difficult to start, then go again for 5 minutes then same again. Have noticed a couple of things but not sure if significant. After driving for 2 minutes with loss of power the bottom plug was wet and other two were dry, could third coil be breaking down under heat? Also on one occassion it went great and only lost power after going to tick over then would not open up again with out stopping when put under load.
Have fitted new plugs, cleaned carbs out, new fuel,
I am thinking its possible electrical?
Any input would be graet as its a bit fraustrating.
Many thanks
Many thanks
