Hi people and thanks in advance for any help you can give me.
I have a Yamaha 50hp 4 stroke of 2000 vintage (F50AET - 200hrs) which is spraying water out externally from around the rubber oil pan drain tube, with nothing from the exit points above the oil drain tube. It looks to be leaking out from the void between the internal oil sump case and the outer leg case around the rubber drain tube if you can get my meaning.
The engine is all ok with no water in oil, telltale working very well and everything running as per normal etc but water is not supposed to come out of that particular spot! I went to a Yamaha dealer today, showed him a video of the problem and he looked at me like a dog which had just been shown a card trick! Held his head to the side and said "bring it in because I have never seen that one before".
Any ideas on how I can fix this and has anyone had this problem?
Thanks again.
