I have a cleaned the fuel system from tank to fuel filter however, at mid range I get a sputter and almost backfire. I put new spark plugs and after running for only a few mintues (using flush kit) the number one plug was fouled a little, the number two fouled a good bit and the third none at all. I believe the carbs need setting but I have no clue how to do this. I also pulled the carbs and cleaned then. I have fresh gas however I've not put in new oil. (oil injected) When I cleaned the carbs the brass vent to the side of the adjustment screw was clogged. (the number three crab.) The adjustment may not be the problem are my only problem so I accept any and all help I can get.<br /><br />Thanks<br />Glenn Spiller
