Yamaha 40 HP (F40LA) New Water Impeller Still won't Pee Water
111torrance111
Installed new Water Impeller in 40 HP motor, won't pee water. Was able to get a couple of drips of water but no stream.
Whhat can I check next?
Jerry
99yam40
1st ,did you put in a kit or just the new impellor?
was the housing still good?
I would try running the motor in a tub of water or on muffs and blow some compressed air up the tell tail hole to see if that moves something out of the way
Water in your tub must be 6" above the impeller.-----Maybe the tell tale hose is plugged.
