Yamaha 40 high revs buzzer sounding.
andymac
Hi <br /><br />The overheat alarm on my 1990 40hp Yam 2cyl 2 stroke sounds at high revs. Last season it sounded at much lower revs leading me to change the thermostat & sender, which has improved it considerably. It seems strange that it has now moved higher up the rev range. I'm wondering what I should look at next. I have a strong tell-tale which is always cool to feel. My prop is 11 1/8 x 13. My boat is 17ft with quite a heavy semi-planing hull that is designed to max at 18 -20 knots with 40hp. I have been told that a 10 pitch would be better but have spoken to someone with an identical boat & engine setup that does not do this. I run in an area that has strong currents but don't think that the currents plus prop load would make the engine overheat. It must be something happening within the engine. I don't have a rev counter but the engine is running quite fast, a good bit over 3/4 throttle before the buzzer sounds. It is happy to cruise at the pre buzzer level for long periods at planing speeds, then that last nudge of the throttle makes it go off. I can throttle back then get back on the plane again once the buzzer goes off, after a minute or so. Is there any point looking at a new water pump if I am getting a strong tell-tale? Anything else I should try? The engine runs perfectly apart from this.<br /><br />Thanks in advance.<br /><br />Andy
