Capt dave 258
- Jul 14, 2021
- 41
I have a 2001, 80hp, Yamaha carbureted 4 stroke that will not start when the engine is cold. I have to give it a shot of starting fluid at the beginning of the day to get it running. It will start fine the rest of the day. I had the carbs cleaned last year by a mechanic. The motor has 2 cold start valves attached to two of the carbs. I tested them by adding 12 volts and they close as they should. I've read that the seals/o-rings may go bad on the valve body. I have a set on order, though mine look fine and I don't believe that's the issue. I ran a 12 volt test light to the wires that supply the valves and it does not light up when the ignition is on. I'm assuming that I am not getting power to the valves for them to operate. I traced the wires back and they clip onto a small, plastic box that also has two other wiring harnesses plugged into it. Any ideas as to how to do further testing to correct the cold start issue? Thanks
