Re: Yamaha 4.3 Water impeller
I'm far from an expert on the matter, but I changed mine in about an hour and a half. The hardest part was taking the water pump off of the block because the bolts hit the pulley when you back them out, so I had to loosen both of them at the same time. I can't speak for the 4.3 but I'm sure it's similar to my 5.7L. There are 2 bolts holding the pump to the block and 2 hoses. One hose goes to the transom housing of the outdrive and one to the GM-style circulating pump on the block. Once the pump is off, there are 3 3/8" bolts holding the rear plate on the pump. When you get the plate off the impeller (in my case) slid right off the shaft. I cleaned the inside with emery cloth, coated everything with lubriplate for the initial dry-start, and had it running in less than 2 hours.
