Yamaha 25 J (30D) 1992 help. I can not remove a piece
grandeand
Hello guys.
My name is Andrea and I write from Italy.
i have a yamaha 25 J which should match the yamaha 30D from 1992.
I cannot remove the flat-faced pin, where the steel lever and the remote control throttle cable hook into.
I put photos of the object of the request!
from the outside, I unscrew the data, remove the washers and remove the steel lever.
from the inside, I detach the advance linkage and push the pin from the outside to the inside.
missing only 5 \ 6 mm to go out, but the internal plastic base slams on the engine block.
do you have any advice?
the images below are taken from the internet, and are used to make it clear what part we are talking about!
1327343984.jpg1610024537.jpgImmagine1.jpgs-l1600 (4)1.jpgImmagine3.jpgs-l1600 (3).jpg
boscoe99
Is the block installed? If so, and it is obstructing the removal of the part, then I would think that the block will have to be removed.
grandeand
yes, these two photos were taken from the internet to make it clear what my problem is. the engine is all assembled!s-l1600 (4)1.jpgs-l1600 (3).jpg
