Re: yamaha 220 no power under load
If compression is good and you're not overheating, then I would go through the carbs again. These engines usually will rev up when not under load. If you're carbs are clogging up, then you need to find out why. You are using fresh gas and a new fuel/water seperator right? And your tank is clean?<br /><br />I went through the same thing a few years ago with an 88 225 Yam that sat for a few years. Fuel contamination was the major issue in getting it running properly. <br /><br />Let me pass on a few things I learned:<br /><br />* It doesn't take much to clog up the carbs. If you do have a fuel contamination problem you are going to have to keep cleaning them until you find out the source of the problem.<br />* The older Yams did not use satinless screws inside their fuel pumps. Therefore they tend to rust which can find its way into the carbs. If you haven't changed them, I would sugget doing so. Don't bother with a rebuild kit, new ones are only about $25 each.<br />* When you change the water pump, be sure to change the T-stats and clean the poppet valve. Even if you're engine is still pee-ing water, the poppet valve may be restricting flow. Sometimes after lay up, the valve sticks.<br /><br />LBI is a great place, I hope to get a house there some day. We have family with a house down on the south end of the island.<br /><br />Good luck.
