Yamaha 2006 f150 lower unit convert from 25" to 20"
cor21e
I just got a great deal on a 2006 f150 with a 25 inch lower.
I need to know how difficult it is to change it over to 20 inch and remove the spacer block
I know I need a new Drive shaft, shift shaft, and water tube, and trim anode bolt.
I have heard that people regularly do this to their engines, But I cannot find any information online on directions.
I appreciate the advice in advance.
tommarvin
Ensign
Free factory service manuals www boatinfo.no/lib/library.html. Click Yamaha Find your 2006 f150.
I have no idea how much it's going to cost to take off 5 inchs, My crabbing bud has a EFI 90 hp,it runs like a car, every time he turns it off in the middle no where my heart stops, but the yam always starts, good for you.
99yam40
I am not sure how much this would cost in parts and labor, but have you thought about a jack plate to raise motor 5 inches
cor21e
It has to go to a 20" shaft. I cannot keep it as a 25" shaft.
When I was looking for these f150 motors for my boat, I would regularly see ads that would say "I can change this to a 20" or 25" shaft at no extra charge"
It made me believe that since there was a 5" spacer on the motor, yamaha made it easy to go back and forth from 20" to 25"
but I cannot find any diy post out there
flyingscott
If you have the 5'" Spacer should be a matter of taking the old parts off and putting new parts in.Depending on how the parts come out of the lower unit will be the biggest issue. Get a service manual. Once you get the new parts in just bolt it back on.
tommarvin
Ensign
Free factory service manuals at www boatinfo.no/lib/library.html There are free yam manuals GA_boater he's a mod here he knows
I saw that same ad 20" 25" I think you need a new drive shaft?
You can't live with the five extra inchs?.
The_Maine_Guy
The conversion is very simple. I went the other direction, purchased a new engine with a 20" but needed 25" for my boat. I purchased a NEW 25" lower unit. I still have the removed, new never used 20" complete lower unit in a box if you need one.
