Yamaha 2006 50 HP Battery drains down after not using for a few weeks.
fc_switch
Battery drains down after not using for a few weeks. This is on a 2006 Yamaha 50 HP 4 stroke. With the motor off and the key out of the ignition, I put a current meter in series with the charging wire and the battery pos terminal, I read 27 mA of DC current. I don't have the wiring diagram for this motor. Does this charge wire come directly from the rectifier? Could this be a diode with high leakage? Or just normal?
puddle jumper
Re: Yamaha 2006 50 HP Battery drains down after not using for a few weeks.
The best thing to do is install a night switch. Your battery may also be not holding a charge and may need replacing.The best way to tell if there is a draw on your battery is to disconnect the negative post/battery clamp and install a test light between the post and clamp and see if it lights up. If it does that means there a power draw. If there is start unplugging fuses on till the light goes out and that will lead you in the right direction.
99yam40
or just use the meter you were using
