Re: yamaha 2005 25hp 2 stroke - will not idle
99yam40 - in most situations you are generally correct... just not in all as you definitively stated.
lilhuna - how many hours on engine? are you at elevation or nearer to sea level? have you moved to elevation? does your primer bulb go soft? does fuel filter bowl stay full? can you advance your throttle slightly and idle then? does fuel filter bowl stay full then? if you can idle your engine by slightly advancing throttle and you have a hand held tachometer, will it hold at 700-800rpm? i live at 7100 ft el and have had 2 outboards NEW out of box. 2004 johnson 9.9 4stroke and jut started breaking in a brand new 2009 yamaha 25 esh 2 stroke.
-Johnson - stalled at idle (FACTORY SETTINGS = properly adjusted motor). Slighly adjusted mechanical idle linkage screw and have never had to do anything to the motor since except plugs, engine and gear oil ( have about 700 hrs on engine).
-Yamaha - stalls at idle (FACTORY SETTING = properly adjusted motor). Have not yet figured out which is the idle adjust screw on the linkage. When I do I will post it. Just raising the idle MAY fix the problem. If you make any adjustments on any linkage screws mark the screw and mounting fixture with paint pen and count your turns so it can be returned if not the issue. Write it down as well so you don't forget!!!!!
