templar33
- Jun 8, 2013
- 6
Hello, I do not have a service manual for my outboard, but I just ordered it and should have it in a few days...
For 2 years since I had the carburetor rebuilt professionally it has run flawlessly, but it is now having problems and running rough and sluggish. When I took the cowling off I noticed that part #18, 65W-14373-00-00 COVER, PLUNGER CAP has broken into pieces and some fuel is leaking out of it now. When I push down on the pieces while running it seems to help make a seal and it begins to run right again. I have this part on order.
***FYI, I always run only non-ethanol fuel I purchase from a local marina, and I treat the fuel with stabilizer and I keep the boat in a garage at all times when not in use, and I run it on a regular basis at least once ever 2 weeks through winter too. So I am wondering why this rubber boot/seal would last only 2 years and if this is normal for it to fail every 2 years??? I see it comes standard with a carburetor repair kit.
But what I would like to ask any of you who might know, I was told by a Mercury outboard technician that I could increase the power of this outboard, my 2003 F25MSHB 4-stroke, by increasing the size of the jets. So I purchased a brand new in the box carburetor for the 2003 F40MSHB for a good price on ebay last year and have it sitting on the shelf keeping it in mind for when a carburetor problem popped up.
To increase power would swapping internal jets be the way to go?
Or, should I just repair the 25hp carburetor and leave it as is?
Not sure if this is important, but the F25MSHB carburetor is model 65W-14901-10-00, and the F40MSHB carburetor is model 67C-14901-13-00
Also, I realize that if I were to increase the power of this outboard with larger jets or, the 40hp carburetor, that I would more than likely have to change the pitch of my propeller up from the 11 pitch I am using now. I have the original 13 pitch prop that came with the outboard, and I also have a brand new 12 pitch prop in the box ready to go. I am familiar with playing around with the prop pitch to achieve optimum running rpm's using a tachometer and following Yamaha specs on this issue.
Any thoughts or comments greatly appreciated! Thanks in advance.
