Yamaha 1991 Shifter coupling assy
davidpiikoi
I am restoring a Baja 225 islander with a 350 gm engine and yamaha marine components. I am new to this and started with a "goodie". Can anyone help me locate a shift assembly or a boot for the shift assy on the outdrive? Thanks for all your help.
Capt Ken
Re: Yamaha 1991 Shifter coupling assy
Do you mean the shift cable and boot?
davidpiikoi
Yes. The shift cable appears fine but the boot appears worn and split. Since I need to replace the boot I thought it would be a good idea to change the cable also.
