Yamaha 1990 4.3L Misfiring. My engine is running on 5 cylinders.
bucaneer
Yamaha 1990 4.3L Misfiring. Number 1 cylinder has a weak spark compared to the other cylinders. It's not the spark plug or lead. Any ideas??
Chief123
I would check the distributor cap an rotor. But not knowing much about the Yamaha system I would post my question in the Yamaha section and you might get better luck with a answer. Good Luck.
jerryjerry05
The system you have on the it's almost impossible to have weak spark on just 1 cyl.
Test the lead, check the cap, do a compression test.
Chief123
Low compression might cause it not to run or miss but it would have nothing to do with spark strength.
