BipolarBear111
- Aug 7, 2024
- 4
Hi all,
I recently got ‘gifted’ 2 old 15hp yamaha outboards. One is siezed so I have dissasembled it for parts. The second one was in seemingly good condition but it wouldn’t run.
I tracked down the cause to it having no compression in the top cylinder. The other cylinder reads around 95psi (see picture)
The top cylinder just has enough compression to make a hiss when I bleed the compression tester but the needle won’t move.
I decided I would disassemble this one and see what was happening. I found a stuck Piston ring and some minor cylinder and piston scoring.
I did a quick hone of the bores and replaced the piston and rings with parts from the spare motor which had one perfect piston and rings that was exactly the same. With lots of swearing trying to fit the needle bearing on the little end bearing I got the job done and attempted to start it.
The compression is still zero psi on the top cylinder after my redneck rebuild. It still gets solid numbers on the bottom cylinder. Damn it….. What have I missed?
There is a chance I got the piston rings mixed up when I installed them but I would have expected to still see some improvement.
One thing I should mention is that I left the head intact during the disassembly process because I am a tight ass and didn’t want to buy a new gasket.
This is where I am thinking I should start looking next.
I have read the reed valves do not affect the compression. So I am ruling that out?
What else in a two stroke can cause compression issues on one cylinder?
I asked my friend who gifted me the outboards and he said the thinks it may have got hot from lack of oil in the fuel. Which would explain the scoring and stuck piston.
I didn’t see any cracks in the bore but couldn’t see too much because I left the head on and the engine is quite small.
I guess the next step is to pull the head off and inspect the gasket and the head for warping.
Please let me know if you have any ideas where the pressure could be leaking out.
You can feel the difference in compression just putting your finger over the spark plug holes, so I am confident in the compression readings.
It would be an awesome to sort this motor as cheaply as possible and put it on my little tinny here on the east coast of AUS.
Thanks in advance for your help.
