hi i have a weird problem with this motor it will not fire on cylinders 2 and 5 we have replaced all the electrical part stator,crank position sensor,cdi pack, and those two coils. do you know what could be the problem ever seen this happen
I had a similar problem, you need to check the yellow wire on the ignition key it needs to have power when you open the key. If it does not have power cyl 2,5 won,t fire. If it is not getting power check all your pin connectors before buying a ignition switch.
