fmt2bx
- May 27, 2015
- 217
Hi!
I have this 1990 130HP Yamaha 2 strokes 130ETXD.
Symptoms:
Idle set at 750rpm, gives me 600/650 when in gear (smooth idle). I advance the throttle slowly and between 800 to 1000/1100 rpm the motor shakes enough to shake the whole boat. Passed 1200rpm, runs great. Cold or hot no difference.
What I have done so far:
1- Removed carbs, cleaned with ultrasonic and set floats at 16mm as per manual. and idle mixture screw set at 7/8 out.
2- Inspected the reeds while carb out, they appeared to be fine.
3- Set the ignition timing as per manual, rods at 53mm and 60 mm. 4 deg ATDC alined the mark on flywheel with trigger mark. set WOT timing at 22 deg BTDC and align mark as well.
Once timing set statically, verified with timing light and it gave me 5 deg ATDC at idle (manual says it should be at 5 deg, so all good there)
4- With carbs mounted, checked the sync and no adjustment needed there. No play either
5- Idle speed screw removed, set the throttle roller to throttle cam as per manual.
6- Started motor and adjusted Idle rpm to 750 in neutral.
7- Fuel pump replaced, not that the old one was bad but that is part of my preventive mx.
8 Checked compression, 125psi on all 4, it has been like this for the past 3 years, no changes there.
9- Did a decarb with seafoam and replaced spark plugs.
So this is where I am and still giving me some shaking between 800 and 1000 rpm.
There is 2 things that I found out while performing the work:
1- The throttle roller has a flat spot
2- After adjusting the timing as per manual, I am a bit dumfounded. After setting the roller with idle screw off, once idle speed adjusted to 750rpm, the roller isn't touching the cam any longer. Then of course when I had throttle, the timing arm advances before the roller touches the cam and adding fuel to motor. I don't get it... I read and re-read the manual to make sure that I understood how to set roller and timing. So why setting timing at 4 deg ATDC if when you advance throttle the timing advances before fuel is added????
Would this explain the shaking?
I would say that the space between roller and cam at idle is about 1.5 mm and that it takes about 7 deg of timing advance before the roller contact the throttle cam. Seems like a lot of advance ???
Anyway, this is where I am and I am in desperate need for help and ideas...
Thank you.
Frederic
Symptoms:
Thank you.
Frederic
