Kola16
- Jun 23, 2019
- 179
1996 Yamaha 130TLRU serial: 6L1 L 308426 X
I am not getting a charge current to my battery. Both my multimeter and sonar agree with that. With everything turned off, my battery was reading 12.8 volts consistently. With the engine running for 5+ minutes at 1750 RPMs, it would only read 12.6 volts. The voltage on my sonar does not seem to go up while running at 4500 RPMs either. So I began testing my charging system.
- It seems I have a good AC voltage out of the stator from the 3 green wires with the engine running. I cannot remember the exact voltages. I also checked the resistance of the 3 green wires with the engine off and they passed the test.
- I then tested the diodes in the rectifier/regulator with the multimeter diode test. They all passed the test.
- I cleaned battery terminals and the grounds on the starter and the rectifier/regulator ground.
- I tried a different battery.
- I unplugged the red wire plug on the rectifier/regulator and tested each end with the engine running. The red wire coming directly out of the rectifier/regulator read 0.65 volts while running. Is that correct? I read someone said this should be 13-14 volts, but cannot find that in a manual. The other end of the red wire plug read 12.6 volts, which seems correct.
Anyway, figuring the rectifier/regulator was the issue, I went to just go order the part ($150). I then made more questions for myself. The original part number is 6R3-81960-00-00 and superseded by 6R3-81960-10-00. The 6R3-81960-10-00; however has an extra red wire coming off the rectifier/regulator that mine does not have. My rect/reg has one red wire, where the part I'm supposed to replace it with has 2 red wires. So what is this second red wire for? Is it for a second battery bank? I am assuming I can just cap it off if I do not need it, correct?
Thanks for any help!
