Oil injection on this engine sucks! The upper reservoir will overfill, & now the oil is being over-pumped or is leaking into my cylinders and it looks like I'm fogging for mosquitos. How do I remove this freakin' pump and sensor and use a premix. Specifically, will the pump fail without oil in it? How do I remove the gear or mechanism from the pump to stop it from pumping? What is the best way to seal the oil feed tubes enter the heads, and what is the best way to jump out the oil level sensors? I'm sure you've addressed this before, where do I need to look or who do I ask? Obi One, you're my only hope.
