i have a 1987 yamaha 115 2 stroke outboard. Main problem was that when it was at full throttle it would go for about 30 seconds then bog out like its not getting enough gas. i thought i could figure it out myself and have worked all summer on it. Here is what i have done so far...compression test good(130 on all) spark test good except on two it was questionable so i replaced two coils, replaced fuel pump,replaced spark plugs, timed motor, replaced fuel tank along with fill hose vent hose and supply line,replaced primer bulb, disassembled and cleaned both carbs, cleaned fuel filter.dont have equipment to check for vacuum leaks.. Now after all that it still does the same thing!!!! i feel very discouraged and a little stupid for putting all the money into it when i should of just taken it to a service shop to begin with but one thing led to another and i thought i was narrowing down the problem. i know now that its not related to the gas so its gotta be something in the motor.. the motor starts great and idles great. its almost like the bowls fill with gas then once its burned i have to throttle down to let them fill up again. wondering if this is carb related..everything looked ok when carbs were apart...please help...thank you..
