Hi,
I have on
2013 Yamaha 115 4stroke outboard power loss problems.
The engine always starts, idle and run at throttle under 3,000 rpm. It bogging down at higher throttle settings and would only run well again after throttling down for a minute or two. The longer I let it struggle at higher throttle the longer it takes to settle down again at lower throttle.
Fuel tank cleaned-ok,
injectors-ok,
fuel/water separator-ok,
fuel filters-ok
What could the problem be?
I have on
injectors-ok,
fuel filters-ok
