Here is a brief synopsis:
BACKGROUND: 1992 Yamaha CVE 2-Stroke Long Shaft, Approx. 4000 hours, Owned Since New, Run Mix Rich @ 25:1
PROBLEM:
Overheats at following rates
COST: US$1,800. Gaskets cost around $300 and the labor is a lot...around 15hours.
PROBLEM:
RPM's Alarm Buzzer Starts (in minutes)
4,800 20 minutes
5,000 3 minutes
6,100 1 minute
TEMPERATURE READINGS:4,800 20 minutes
5,000 3 minutes
6,100 1 minute
Engine With Cooling Problem
Head 1 139 degrees
Head 2 142 degrees
Exhaust Water 118 degrees
Head 2 142 degrees
Engine WithOut Cooling Problem
Head 1 127.5 degrees
Head 2 127 degrees
Exhaust Water 110 degrees
DIAGNOSIS:Head 2 127 degrees
- R&R Water Pump (impellar) and it did nothing to resolve cooling temperature
- R&R Pressure Relief Valve (poppit) and again did nothing to resolve overheating
- Removed Powerhead and replaced adaptor plate
- Removed Heads and sandblasted them
- Cleaned water jackets
- Cleaned and/or replaced cooling hoses
