Re: yamaha 115 1990 oil/fuel injection!
I have a brand new v4 115 yamaha it has a emergency switch on a plate on the motor to pump oil from tank to smaller resevoir also these type oilers only work when the flywheel is turning some one else had same problem said same thing to him the manual says check for engine overheating first thenand then oil level then oil filter clogging
